		| Auteur | Message |
		| Cyrillo PowerBook Duo 230
				|  Posté le: Sam 05 Sep 2009 à 12:55    Sujet du message: |   |
				| saft ça fait quoi exactement ??? _________________
 OS X EL CAPITAN
 IPHONE 6S 64GO
  , touchpad, ipad pro 9.7 128go, ipod et cie... |  |
				|  Posté le: Sam 05 Sep 2009 à 13:07    Sujet du message: |   |
				| j'ai des plantages avec snow, ical voir safari (a quitté de manière imprévue)... avec le triangle jaune avec ! blanc... _________________
 OS X EL CAPITAN
 IPHONE 6S 64GO
		| love_leeloo PowerBook G3 Bronze
				|  Posté le: Sam 05 Sep 2009 à 13:14    Sujet du message: |   |
				|  	  | Cyrillo a écrit: |  	  | saft ça fait quoi exactement ??? |
  	  | Citation: |  	  | Ad/banner blocking with simple URL pattern matching Add bookmark folder here and add bookmark here in every bookmark menus
 Always open browser window in tab
 Auto hide Downloads window
 Auto save and restore opened browser windows at quitting and start
 AutoComplete always on
 Block animation
 Block HTML refreshing in front-most browser
 Block images and plugins
 Bookmark search
 Bookmark this group of tabs
 Consolidate browser windows
 Control-1 to 9 to popup bookmark menu or open bookmark
 Control-drag page
 Crash protection
 Create dated folder for downloaded files
 Customizable HTTP timeout
 Customized Google search field
 Do not allow scripts to bring tab to front
 Drag tab buttons to add the URL string to other applications
 Enter/ctrl-enter to go to next/previous links (like in Google)
 Export Selected Bookmarks
 Extended search from contextual menu
 External text editor support for TextArea
 Fix for Frame Creation Attack
 Fix for Safari AutoFill Information Disclosure
 Focus the last selected tab when closing the current one
 Full-screen browsing
 Google Safe Browsing
 Growl support
 History search
 Install debug menu
 Kiosk mode
 Max screen for normal browser windows
 Modified "Open in Tabs"
 One-page PDF export
 Open tab in new window
 Option to use Aqua interface
 Original URLs in Spotlight comments of downloaded files, exported PDFs and saved pages
 Plain copy
 Print All
 Reload All Tabs
 Reversed tab order
 Save and load browser windows
 Save tabs and save all
 Separator in bookmark menu
 Shortcut for Look Up in Dictionary
 Sidebar
 Sort bookmarks in every bookmark menus
 Stop download warnings
 Tab rearranging with drag and drop
 Tab search
 Tab thumbnails
 Type-ahead searching
 Undo support for closing tab and closing other tabs
 URL shortcuts
 URL traverse with return-key
 Work-around of click-through bug in WebKit
				|  Posté le: Sam 05 Sep 2009 à 13:59    Sujet du message: |   |
				| j'ai voulu lancer onyx mais pas compatible snow.je vais donc attendre la prochaine version. _________________
 OS X EL CAPITAN
 IPHONE 6S 64GO
		| ch-vox Modérateur
				|  Posté le: Sam 05 Sep 2009 à 21:37    Sujet du message: |   |
				|  	  | Cyrillo a écrit: |  	  | safari est mon navigateur par défaut mais firefox j'en ai besoin par exemple pour ebay car lors de création d'annonce pour mettre de la couleur etc... il me demande de mettre du langage html et firefox non. et aussi sur firefox j'ai une option de mot de passe principal bien utile qui n'existe pas sur safari et dernier point lors du téléchargement safari ne me propose pas de choisir l'endroit ou mettre le fichier "toujours demander où enregistrer les fichiers" (je dois choisir un répertoire obligatoirement) sinon je le dégagerai car c'est clair safari il est super rapide |
 suis d'accord avec toi, chez moi, Firefox je l'utilise pour ma déclaration d'impôts.
				|  Posté le: Sam 05 Sep 2009 à 21:44    Sujet du message: |   |
				| c'est vrai le mot de passe principal je trouve ça utile, ça n existe pas sur safari dommage... _________________
 OS X EL CAPITAN
 IPHONE 6S 64GO
		| ch-vox Modérateur
				|  Posté le: Sam 05 Sep 2009 à 21:48    Sujet du message: |   |
				| c'était surtout pour un souci de certificat non compatible.... _________________
		| ch-vox Modérateur
				|  Posté le: Dim 06 Sep 2009 à 8:31    Sujet du message: |   |
				|  	  | love_leeloo a écrit: |  	  | http://gizmodo.com/5346418/snow-leopard-review-lightened-and-enlightened |
 tiens, un nouvel article :
 http://gizmodo.com/5352889/mac-os-x-snow-leopard-the-complete-guide
				|  Posté le: Lun 07 Sep 2009 à 9:00    Sujet du message: |   |
				| tiens depuis que j'ai installé 10.6, lorsque je mets mon ordi en veille (en le fermant), et bien 1 min après il sort de veille pour y retourner instantanément. et cela toute les min au moins .... pas de souci de votre coté ?
		| PhilippeL PowerBook Duo 210
				|  Posté le: Lun 07 Sep 2009 à 9:40    Sujet du message: |   |
				| pour moi tout roule, j'ai juste "perdu" quelques économiseurs d'écran ...  |  |
				|  Posté le: Lun 07 Sep 2009 à 10:39    Sujet du message: |   |
				| pour le souci de veille :
 Dans MacintoshHD/Bibliothèque/Preference/SystemConfiguration
 effacer le fichier com.apple.AutoWake.plist
 Mais attention il arrive que ce fichier réapparaisse, du coup il faut à nouveau l'effacer !
				|  Posté le: Lun 07 Sep 2009 à 14:46    Sujet du message: |   |
				| bah, j'ai viré les savers ... à l'occasion j'installerai de nouveau et j'essaierai ta manip'  Merci ! |  |
				|  Posté le: Lun 07 Sep 2009 à 15:02    Sujet du message: |   |
				| nan, pardon, la manip est pour MON pb
 pour le tien, il suffit de mettre les prefs systeme en 32bits
		| ch-vox Modérateur
				|  Posté le: Mar 08 Sep 2009 à 0:14    Sujet du message: |   |
				|  	  | love_leeloo a écrit: |  	  | pour le souci de veille :
 j'ai pas eu ce souci, on n'en connaît pas l'origine ?  (qui crée ce fichier ?)
				|  Posté le: Mar 08 Sep 2009 à 8:19    Sujet du message: |   |
				| non j'ai regardé vite fait les forums, et j'ai trouvé ça, je n'ai pas approfondi |  |
				|  Posté le: Mar 08 Sep 2009 à 9:30    Sujet du message: |   |
				|  	  | love_leeloo a écrit: |  	  | nan, pardon, la manip est pour MON pb
 OK ! Merci m'sieur
				|  Posté le: Mar 08 Sep 2009 à 10:02    Sujet du message: |   |
				| par contre tu perds l'utilisation des screensaver 64bits  |  |
				|  Posté le: Ven 11 Sep 2009 à 20:36    Sujet du message: |   |
 heu et on fait comment ça ?!?
				|  Posté le: Ven 11 Sep 2009 à 20:38    Sujet du message: |   |
				|  trouvé !  |  |
				|  Posté le: Mer 23 Sep 2009 à 8:59    Sujet du message: |   |
 Bon, alors les savers fonctionnent si on les lance manuellement, sinon, nada !
