Changer la pile d'un Wallstreet
Chong
PowerBook d'Etain
PowerBook d'Etain
MessagePosté le: Jeu 18 Déc 2003 à 11:50    Sujet du message: Répondre en citant
Désolé...
Voici ce que j'ai trouvé pour rebooter sous OS 9. Je sais pas si tu as déjà essayé ça...
Citation:
Switching between Mac OS 9 and Mac OS X
Once you have installed Mac OS X, you may want to reboot into Mac OS 9 at some point. One way to do this is to hold down the option-key while restarting. However, it sometimes happens that when you install Mac OS X, your Mac OS 9 System Folder becomes "unblessed." In this case, you can use the "Startup Disk" panel in the Mac OS X "System Preferences" application. This will re-bless the System Folder and permit you to reboot into Mac OS 9.
After you reboot into Mac OS 9, you can use XPostFacto to return to Mac OS X. Simply select the desired startup volume and press the restart button. XPF will write the required settings to non-volatile RAM (NVRAM), and restart the computer. (Restarting from the Finder is not affected by your selection here.
XPF will only startup Mac OS X. To choose a different Mac OS 9 volume, use the Startup Disk control panel instead. However, do not use Startup Disk to choose a Mac OS X volume on unsupported machines, as it will not work, and may require you to zap your parameter RAM.
source : XPostFacto
Nat
Powerbook G4 1Ghz - 17" - 1 Go Ram - 60Go - Bluetooth - Airport Extreme + ibook 12'' 800Mhz - 512 mo Ram + Powerbook G3 300 - 14" - 384 Mo Ram - 1Mo L2 - 40Go 5400 Tr/min - 10.4.5 - Carte USB2 - DD 250 Go en USB2 - Clé Wifi 54
vinc38
PowerBook de Froment
MessagePosté le: Jeu 18 Déc 2003 à 12:09    Sujet du message: Répondre en citant
effectivement c'est une solution.
contrairement a ce que je disais c'est plus le nvram qui compte que le L2.
le soucis avec cette solution c'est que tu desactives les extansions et donc l'extansion bootx qui permet de booter linux avant qu'il est completement charge os9. (il a l'extension bootx et l'appli bootx) Confused
je sais : je veux le beurre et l'argent mais .....
merci Smile
a garder
Page 2 sur 2
