ProToS PowerBook de Cuir
Posté le: Sam 18 Juin 2005 à 9:12 Sujet du message: |
A priori tant que le disque n'est pas monté rien ne sert de s'alarmer.
Le soucis n'a été rencontré qu'avec des IBM si mes souvenirs sont bons.
Maintenant l'avantage de la lame de cutter, c'est pas tant sa composition, mais surtout sa forme (fine)... _________________ Ludovic
Posté le: Dim 19 Juin 2005 à 1:02 Sujet du message: |
j'en suis pas sur
xlr8yourmac hard drive database
Citation: |
Reviewer's Name: Dan Phillips
Date Submitted: 5/14/2005
Drive Type: Hard Drive
Drive Interface: IDE
Drive Brand: Samsung
Drive Model Number: MP0402H
Drive Size: 40 GB
Driver Used: Apple Standard
Mac Model: PowerBook G3 Wallstreet 2 RageProLT
Mac OS Version: OS X
Reader Comments: OS 10.2.8. Drive installed with no trouble. I formatted and did a clean OS X install on the first (<8 GB) partition.
It's practically silent whether accessing or idle, an ENORMOUS improvement over the 8 GB original drive, and much faster. I have not run across any wake-from-sleep difficulties that were due to the drive.
As an aside, there is a separate problem with these powerbooks in which the machine wakes but the screen backlight does not (so you can "use" the powerbook while shining a very bright light on the screen). Problem disappears on reboot, and then reoccurs again every time the computer sleeps. The problem is separate from other display problems that are due to hinge difficulties, in that it appears to be software-based.
Resetting the power manager and other techniques had no effect, but one suggestion I found has worked both times this problem has occurred: boot into OS 9, put the computer to sleep, wake it up again, and then boot back into OS X. Weird.
Thanks for the site! I've gotten great use from it.
-Dan
Mike Comments: Thanks.
(reader FYI - Powerbook G3 1998/wallstreet illustrated HD install guide here)
_________________ SeeU
[ProToS] on ircnet
chan #atari.fr #atariscne
F030 Moderator on Atari-Forum |
Posté le: Dim 19 Juin 2005 à 8:06 Sujet du message: |
Mais il n'empeche que seul l'installation peut le confirmer. _________________ Ludovic
ThiGre PowerBook de Basane
Posté le: Dim 19 Juin 2005 à 11:42 Sujet du message: |
Deux IBM TravelStars 20 Go
Un dans le WallStreet de mon ex (un 250)
L'autre dans mon WallStreet (un 266)
J'ai pas eu de problème, mais il a fallut la lame de cutter pour celui de mon ex...
Ceci dit c'était il y a longtemps, bien longtemps dans une galaxie lointaine...
En 1999 si je me souviens bien.
Alors
1) il faut installer pour savoir
2) Si tu as ce problème, pourquoi veux-tu changer une solution (la lame de cutter) qui est simple et qui marche ? _________________ MBP 15.4" SSD+HD, 1.8.5 + Mavericks GM
Posté le: Mar 21 Juin 2005 à 2:28 Sujet du message: |
ThiGre a écrit: |
2) Si tu as ce problème, pourquoi veux-tu changer une solution (la lame de cutter) qui est simple et qui marche ? |
1) pas de problème
2) c'est juste le fait que ce soit justement une lame qui me gène _________________ SeeU
[ProToS] on ircnet
Posté le: Mer 29 Juin 2005 à 0:02 Sujet du message: |
bon voilà, 1ère tentative et enorme échec
j'ai tenté d'installé 8.6 et 9.2.2 et bien impossible .... dans les 2 cas
j'ai eut un gel total du powerbook
(comme ici http://www.powerbook-fr.com/forum/viewtopic.php?p=77063#77063 mais là 8.6 c'etait bien installé)
je pense a une petite "allergie" a la crescendo G4@500
vais réinstallé la vielle carte fille G3@250 et retenté le coup. _________________ SeeU
[ProToS] on ircnet
Posté le: Mer 29 Juin 2005 à 4:21 Sujet du message: |
c'est bien une "allergie" a la crescendo G4 @500
tout c'est bien passé avec la carte fille d'origine G3 @250
une foi l'install de 8.6 et 9.2.2 j'ai procédé a l'upgrade vers la crescendo
et pour le moment tout tourne normalement _________________ SeeU
[ProToS] on ircnet
Posté le: Mer 29 Juin 2005 à 8:18 Sujet du message: |
Finalement tu avais peur du "magnetic sensor" et c'est autre chose qui a gêné  _________________ Ludovic
iClyde PowerBook de Cuir
Posté le: Mer 29 Juin 2005 à 10:27 Sujet du message: |
ProToS a écrit: | c'est bien une "allergie" a la crescendo G4 @500
et pour le moment tout tourne normalement |
Pardon, mais que veux tu dire par "allergie"?
Car, moi aussi, quand j'ai changé de dd (hitachi 7200), j'ai eu le problème de "magnetic sensor" et la lame de cutter a tout réglé, mais j'avais encore la G3 233. Puis j'ai mis la G4 500 qui a marché 6mois puis gel en fin de démarrage. Avec la G3, tout remarche. Donc, il semblerait que mon problème soit différent du tien?
De toute façon, la carte vient de partir en SAV |
Posté le: Jeu 30 Juin 2005 à 23:11 Sujet du message: |
lpascalon a écrit: | Finalement tu avais peur du "magnetic sensor" et c'est autre chose qui a gêné  |
et pour le moment je ne risque pas de voir si le problème du "magnetic sensor",
j'ai désactivé la mise en veille sous 8.6 et 9.2.2, faut dire que je m'en sert casiment
jamais en nomade.
iClyde a écrit: |
j'entent pas "allergie" qu'il ma été impossible d'installé 8.6 et 9.2.2 temps que le G4 etait installé
avec le samsung MP0402H
et aussi sur le bon vieux disque dur d'origine c'etait 9.2.2 qui refusé de s'installé avec le G4
dans ses 3 cas j'ai eut un gel total du powerbook, tout etait freezé.
conclusion pour moi si je doit un jour réinstallé macos remplacé le G4 par le bon vieux G3
je me pose même la question si un jour je tente d'installé osX via xpostfacto le même
problème risque de revenir...
enfin pour le moment j'ai rien décidé pour osX _________________ SeeU
[ProToS] on ircnet
Posté le: Dim 21 Aoû 2005 à 1:56 Sujet du message: |
juste pour dire que le problème du "magnetic sensor" existe bien avec ce disque dur voilà. _________________ SeeU
[ProToS] on ircnet
