Problème de switch dans la prise audio MAcBook pro
Poster un nouveau sujet   Répondre au sujet    Tout sur les MacBook Index du Forum -> Forum générique MacBook Pro
Claude Desjardins
MessagePosté le: Mer 06 Sep 2006 à 9:29    Sujet du message: Problème de switch dans la prise audio MAcBook pro Répondre en citant
J'ai fait quelques recherches, voici ce que j'ai trouvé sur mon problème audio.
J'ai un MAcBook Pro, et la solution proposée par ces personnes me semblent un peu périlleuse. Quelqu'un a-t-il eu le même problème et qu'avez-vous fait?
- Problème de switch dans la prise audio. Voici ce que j'ai trouvé qui explique exactement mon problème ( en anglais malheureusement)
Mr.B., I just got a reply on this subject from a very helpful man in Germany, who said there is a mechanical switch in the headphone jack which turns off the built-in speakers when a plug is inserted, which can get stuck. You can try plugging and unplugging repeatedly to free this switch if that is the problem. I tried feeling around in the jack lightly with a wooden toothpick, and the built-in speakers magically kicked in again, so I believe the stuck switch was my problem. Perhaps this will work for you. If you do feel around in the jack, be sure, of course, to use a non-metallic probe such as a wood toothpick, and be very gentle! I hope this helps... Aloha!
I had this exact same problem - red digital out light coming from the sound out port, and no internal speakers. I tried the jiggle the jack thing, and it worked a couple of times and then stopped.
A bit skeptical, I tried the toothpick probe. To my amazement, it worked. I really hope that this problem doesn't come back. Do you have any idea where the switch was inside of the headphone jack, in case I or others need to do this again?
I thought that I head a slight mechanical pop (like a switch getting un-stuck?) when I probed on the left side of the headphone port (as one looks into the port from the outside).
t felt like it was on the left side, yes. I did this twice, and maybe the dust or whatever that was making the switch stick came loose, or whatever, but I haven't had to repeat the toothpick thing since (several re-pluggings later).
Claude
ONS99
MessagePosté le: Mer 06 Sep 2006 à 9:57    Sujet du message: Répondre en citant
Salut Claude et bienvenue,
je crois que tu aurais avantage à expliquer succinctement ton problème… Perso, d'après ce que j'ai compris de la solution, je n'ai pas été confronté à ce type d'ennui.
Éric
MessagePosté le: Sam 09 Sep 2006 à 5:25    Sujet du message: Répondre en citant
il s'agit en effet d'un micro interrupteur sous forme de languette qui pose parfois souci de façon aléatoire. j'ai également le même problème sur mon powerbook, je l'avais envoyé en SAV pour cette raison précise mais Apple n'avait à l'époque rien pu diagnostiquer.
le fait d'enclencher et désenclencher la prise jack de façon répétitive m'a permis d'assouplir se contacteur qui est maintenant revenu en position ouverte (HP actif), mais quand j'utilise la sortie son sur une chaîne hi-fi par exemple, le souci a tendance à revenir.
Poster un nouveau sujet   Répondre au sujet    Tout sur les MacBook Index du Forum -> Forum générique MacBook Pro Toutes les heures sont au format GMT + 2 Heures
