jazzyguy PowerBook de Cuir
Inscrit le: 09 Mar 2005 Messages: 23 Localisation: La Varenne-St Hilaire, France
Posté le: Sam 23 Avr 2005 à 12:43 Sujet du message: Wallstreet / OS 10.3.9 et SCSI |
J'utilise OS 10.3.9 sur mon Wallstreet (après une installation initiale avec XPostFacto), mais je n'arrive toujours pas à voir mon graveur externe connecté en SCSI : voici ce que me donne la commande ioreg, si quelqu'un pouvait m'aider à résoudre ce problème, je lui en serais reconnaissant.
Merci d'avance,
____________________________________________________________________________
PBook1:~ Guy$ ioreg
+-o Root <class IORegistryEntry, retain count 11>
+-o AAPL,PowerBook1998 <class IOPlatformExpertDevice, registered, matched, active, busy 0, retain count 17>
+-o GossamerPE <class GossamerPE, !registered, !matched, active, busy 0, retain count 9>
| +-o IOPMrootDomain <class IOPMrootDomain, registered, matched, active, busy 0, retain count 26>
| | +-o IORootParent <class IORootParent, !registered, !matched, active, busy 0, retain count 8>
| | +-o RootDomainUserClient <class RootDomainUserClient, !registered, !matched, active, busy 0, retain count 5>
| +-o options@0 <class IODTNVRAM, registered, matched, active, busy 0, retain count 7>
| +-o PowerPC,G4@0 <class IOPlatformDevice, registered, matched, active, busy 0, retain count 8>
| | +-o GossamerCPU <class GossamerCPU, registered, matched, active, busy 0, retain count 6>
| | +-o IOCPUInterruptController <class IOCPUInterruptController, registered, matched, active, busy 0, retain count 6>
| +-o cpus@0 <class IOPlatformDevice, registered, matched, active, busy 0, retain count 7>
| +-o pci@80000000 <class IOPlatformDevice, registered, matched, active, busy 0, retain count 13>
| +-o AppleGracklePCI <class AppleGracklePCI, registered, matched, active, busy 0, retain count 17>
| +-o mac-io@10 <class IOPCIDevice, registered, matched, active, busy 0, retain count 17>
| | +-o Heathrow <class Heathrow, registered, matched, active, busy 0, retain count 30>
| | +-o mesh@10000 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 7>
| | | +-o meshSCSIController <class meshSCSIController, registered, matched, active, busy 0, retain count 6>
| | +-o escc@13000 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 8>
| | +-o ch-a@13020 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 7>
| | | +-o AppleSCCSerial <class AppleSCCSerial, !registered, !matched, active, busy 0, retain count 5>
| | | +-o AppleSCCRS232SerialStreamSync <class AppleSCCRS232SerialStreamSync, registered, matched, active, busy 0, retain count 5>
| | | +-o IOSerialBSDClient <class IOSerialBSDClient, registered, matched, active, busy 0, retain count 4>
| | +-o ch-b@13000 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 7>
| | +-o bmac@11000 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 7>
| | | +-o BMacEnet <class BMacEnet, !registered, !matched, active, busy 0, retain count 8>
| | | +-o IOEthernetInterface <class IOEthernetInterface, registered, matched, active, busy 0, retain count 10>
| | | | +-o IONetworkStack <class IONetworkStack, registered, matched, active, busy 0, retain count 9>
| | | | +-o IONetworkStackUserClient <class IONetworkStackUserClient, !registered, !matched, active, busy 0, retain count 5>
| | | +-o IOKernelDebugger <class IOKernelDebugger, registered, matched, active, busy 0, retain count 8>
| | | +-o IOKDP <class IOKDP, registered, matched, active, busy 0, retain count 4>
| | +-o davbus@14000 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 8>
| | | +-o AppleScreamerAudio <class AppleScreamerAudio, registered, matched, active, busy 0, retain count 21>
| | | +-o IOAudioPort <class IOAudioPort, registered, matched, active, busy 0, retain count 6>
| | | +-o IOAudioPort <class IOAudioPort, registered, matched, active, busy 0, retain count 7>
| | | +-o Apple02DBDMAAudioDMAEngine <class Apple02DBDMAAudioDMAEngine, registered, matched, active, busy 0, retain count 25>
| | | +-o IOAudioSelectorControl <class IOAudioSelectorControl, !registered, !matched, active, busy 0, retain count 10>
| | | | +-o IOAudioControlUserClient <class IOAudioControlUserClient, !registered, !matched, active, busy 0, retain count 6>
| | | +-o IOAudioLevelControl <class IOAudioLevelControl, !registered, !matched, active, busy 0, retain count 10>
| | | +-o IOAudioToggleControl <class IOAudioToggleControl, !registered, !matched, active, busy 0, retain count 10>
| | | +-o IOAudioToggleControl <class IOAudioToggleControl, !registered, !matched, active, busy 0, retain count 9>
| | | +-o IOAudioStream <class IOAudioStream, registered, matched, active, busy 0, retain count 6>
| | | +-o IOAudioEngineUserClient <class IOAudioEngineUserClient, !registered, !matched, active, busy 0, retain count 6>
| | +-o sound@0,0 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 12>
| | +-o media-bay@34 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 9>
| | | +-o AppleMediaBay <class AppleMediaBay, registered, matched, active, busy 0, retain count 7>
| | +-o floppy@15000 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 6>
| | +-o ata1@21000 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 7>
| | | +-o AppleMediaBayATANub <class AppleMediaBayATANub, registered, matched, active, busy 0, retain count 8>
| | | +-o HeathrowATA <class HeathrowATA, !registered, !matched, active, busy 0, retain count 5>
| | | +-o ATADeviceNub@0 <class ATADeviceNub, registered, matched, active, busy 0, retain count 6>
| | | +-o IOATAPIProtocolTransport <class IOATAPIProtocolTransport, registered, matched, active, busy 0, retain count 9>
| | | +-o IOSCSIPeripheralDeviceNub <class IOSCSIPeripheralDeviceNub, registered, matched, active, busy 0, retain count 5>
| | | +-o IOSCSIPeripheralDeviceType05 <class IOSCSIPeripheralDeviceType05, !registered, !matched, active, busy 0, retain count 7>
| | | +-o IOCompactDiscServices <class IOCompactDiscServices, registered, matched, active, busy 0, retain count 5>
| | | +-o IOCDBlockStorageDriver <class IOCDBlockStorageDriver, registered, matched, active, busy 0, retain count 5>
| | +-o ata0@20000 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 19>
| | | +-o IOATABlockStorageDriver <class IOATABlockStorageDriver, registered, matched, active, busy 0, retain count 7>
| | | +-o IOATABlockStorageDevice <class IOATABlockStorageDevice, registered, matched, active, busy 0, retain count 5>
| | | +-o IOBlockStorageDriver <class IOBlockStorageDriver, registered, matched, active, busy 0, retain count 7>
| | | +-o HTS548040M9AT00 Media <class IOMedia, registered, matched, active, busy 0, retain count 10>
| | | +-o IOMediaBSDClient <class IOMediaBSDClient, registered, matched, active, busy 0, retain count 5>
| | | +-o IOApplePartitionScheme <class IOApplePartitionScheme, !registered, !matched, active, busy 0, retain count 15>
| | | +-o Apple@1 <class IOMedia, registered, matched, active, busy 0, retain count 8>
| | | +-o Macintosh@2 <class IOMedia, registered, matched, active, busy 0, retain count 8>
| | | +-o Macintosh@3 <class IOMedia, registered, matched, active, busy 0, retain count 8>
| | | +-o Macintosh@4 <class IOMedia, registered, matched, active, busy 0, retain count 8>
| | | +-o Macintosh@5 <class IOMedia, registered, matched, active, busy 0, retain count 8>
| | | +-o Macintosh@6 <class IOMedia, registered, matched, active, busy 0, retain count 8>
| | | +-o Macintosh@7 <class IOMedia, registered, matched, active, busy 0, retain count 8>
| | | +-o Patch Partition@8 <class IOMedia, registered, matched, active, busy 0, retain count 8>
| | | +-o sans titre@9 <class IOMedia, registered, matched, active, busy 0, retain count 9>
| | | | +-o IOMediaBSDClient <class IOMediaBSDClient, registered, matched, active, busy 0, retain count 6>
| | | +-o sans titre 2@10 <class IOMedia, registered, matched, active, busy 0, retain count 9>
| | | +-o sans titre 3@11 <class IOMedia, registered, matched, active, busy 0, retain count 9>
| | +-o via-pmu@16000 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 13>
| | | +-o AppleVIA <class AppleVIA, !registered, !matched, active, busy 0, retain count 5>
| | | +-o pmu <class AppleVIADevice, registered, matched, active, busy 0, retain count 6>
| | | +-o ApplePMU <class ApplePMU, registered, matched, active, busy 0, retain count 14>
| | | +-o IOPMUNVRAMController <class IOPMUNVRAMController, !registered, !matched, active, busy 0, retain count 5>
| | | +-o IOPMURTCController <class IOPMURTCController, !registered, !matched, active, busy 0, retain count 5>
| | | +-o IOPMUPwrController <class IOPMUPwrController, !registered, !matched, active, busy 0, retain count 5>
| | +-o adb@0,0 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 9>
| | | +-o IOPMUADBController <class IOPMUADBController, !registered, !matched, active, busy 0, retain count 8>
| | | +-o 2-c4@2 <class IOADBDevice, registered, matched, active, busy 0, retain count 6>
| | | | +-o AppleADBKeyboard <class AppleADBKeyboard, registered, matched, active, busy 0, retain count 8>
| | | | +-o IOHIDSystem <class IOHIDSystem, registered, matched, active, busy 0, retain count 14>
| | | | | +-o IOHIDUserClient <class IOHIDUserClient, !registered, !matched, active, busy 0, retain count 5>
| | | | | +-o IOHIDParamUserClient <class IOHIDParamUserClient, !registered, !matched, active, busy 0, retain count 5>
| | | | +-o IOBSDConsole <class IOBSDConsole, !registered, !matched, active, busy 0, retain count 8>
| | | | +-o IOHIDKeyboardDevice <class IOHIDKeyboardDevice, registered, matched, active, busy 0, retain count 6>
| | | | +-o IOHIDLibUserClientIniter <class IOHIDLibUserClientIniter, !registered, !matched, active, busy 0, retain count 4>
| | | +-o 3-01@3 <class IOADBDevice, registered, matched, active, busy 0, retain count 6>
| | | | +-o AppleADBMouseType4 <class AppleADBMouseType4, registered, matched, active, busy 0, retain count 7>
| | | | +-o IOHIDPointingDevice <class IOHIDPointingDevice, registered, matched, active, busy 0, retain count 6>
| | | +-o 7-1f@7 <class IOADBDevice, registered, matched, active, busy 0, retain count 6>
| | | +-o AppleADBButtons <class AppleADBButtons, registered, matched, active, busy 0, retain count 7>
| | +-o keyboard@0,0 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 6>
| | +-o nvram@0,0 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 6>
| | +-o power-mgt@0,0 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 8>
| | +-o battery@0,0 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 9>
| | +-o backlight@F300,0 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 7>
| | +-o ApplePMUPanel <class ApplePMUPanel, !registered, !matched, active, busy 0, retain count 5>
| +-o mac-io@D <class IOPCIDevice, registered, matched, active, busy 0, retain count 12>
| | +-o Heathrow <class Heathrow, registered, matched, active, busy 0, retain count 13>
| | +-o escc@13000 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 7>
| | | +-o AppleSCCModem <class AppleSCCModem, registered, matched, active, busy 0, retain count 7>
| | +-o ata4@21000 <class AppleMacIODevice, registered, matched, active, busy 0, retain count 7>
| | +-o AppleMediaBayATANub <class AppleMediaBayATANub, !registered, !matched, active, busy 0, retain count 6>
| +-o ATY,RageLTPro@11 <class IOPCIDevice, registered, matched, active, busy 0, retain count 13>
| | +-o GossamerNDRVSupport <class GossamerNDRVSupport, !registered, !matched, active, busy 0, retain count 4>
| | +-o .Display_ATImach64_3DR3-0100800b <class IOATINDRV, registered, matched, active, busy 0, retain count 11>
| | +-o display0 <class IODisplayConnect, registered, matched, active, busy 0, retain count 5>
| | | +-o AppleBacklightDisplay <class AppleBacklightDisplay, registered, matched, active, busy 0, retain count 7>
| | +-o IOFramebufferUserClient <class IOFramebufferUserClient, !registered, !matched, active, busy 0, retain count 5>
| +-o pccard@13 <class IOPCIDevice, registered, matched, active, busy 0, retain count 11>
| | +-o IOPCCardBridge <class IOPCCardBridge, registered, matched, active, busy 0, retain count 6>
| | +-o OpenPMUPCCardEject <class OpenPMUPCCardEject, !registered, !matched, active, busy 0, retain count 4>
| +-o pccard@13,1 <class IOPCIDevice, registered, matched, active, busy 0, retain count 11>
| +-o IOPCCardBridge <class IOPCCardBridge, registered, matched, active, busy 0, retain count 16>
| | +-o pci10b9,5237@0 <class IOCardBusDevice, registered, matched, active, busy 0, retain count 11>
| | | +-o AppleUSBOHCI <class AppleUSBOHCI, registered, matched, active, busy 0, retain count 8>
| | | | +-o OHCI Root Hub Simulation@0 <class IOUSBRootHubDevice, registered, matched, active, busy 0, retain count 11>
| | | | | +-o AppleUSBHub <class AppleUSBHub, !registered, !matched, active, busy 0, retain count 4>
| | | | | +-o IOUSBInterface@0 <class IOUSBInterface, !registered, !matched, active, busy 0, retain count 5>
| | | | | +-o IOUSBUserClientInit <class IOUSBUserClientInit, !registered, !matched, active, busy 0, retain count 4>
| | | | +-o USB Receiver@100000 <class IOUSBDevice, registered, matched, active, busy 0, retain count 9>
| | | | +-o AppleUSBComposite <class AppleUSBComposite, !registered, !matched, active, busy 0, retain count 4>
| | | | +-o IOUSBInterface@0 <class IOUSBInterface, registered, matched, active, busy 0, retain count 6>
| | | | | +-o com_Logitech_USBMouse <class com_Logitech_USBMouse, !registered, !matched, active, busy 0, retain count 5>
| | | | | | +-o com_Logitech_HIDevice <class com_Logitech_HIDevice, !registered, !matched, active, busy 0, retain count 10>
| | | | | | +-o com_Logitech_HIPointing <class com_Logitech_HIPointing, registered, matched, active, busy 0, retain count 9>
| | | | | | +-o com_Logitech_HIKeyboard <class com_Logitech_HIKeyboard, registered, matched, active, busy 0, retain count 9>
| | | | | | +-o com_Logitech_HISpecialKeys <class com_Logitech_HISpecialKeys, registered, matched, active, busy 0, retain count 8>
| | | | | | +-o com_Logitech_HILLEventQueue <class com_Logitech_HILLEventQueue, !registered, !matched, active, busy 0, retain count 5>
| | | | | | +-o com_Logitech_HIDeviceUserClient <class com_Logitech_HIDeviceUserClient, !registered, !matched, active, busy 0, retain count 5>
| | +-o pci10b9,5237@0,1 <class IOCardBusDevice, registered, matched, active, busy 0, retain count 11>
| | | +-o AppleUSBOHCI <class AppleUSBOHCI, registered, matched, active, busy 0, retain count 7>
| | | | +-o OHCI Root Hub Simulation@0,1 <class IOUSBRootHubDevice, registered, matched, active, busy 0, retain count 9>
| | +-o pci10b9,5237@0,2 <class IOCardBusDevice, registered, matched, active, busy 0, retain count 11>
| | | | +-o OHCI Root Hub Simulation@0,2 <class IOUSBRootHubDevice, registered, matched, active, busy 0, retain count 9>
| | +-o pci10b9,5239@0,3 <class IOCardBusDevice, registered, matched, active, busy 0, retain count 12>
| | | +-o IOService <class IOService, !registered, !matched, active, busy 0, retain count 4>
| | | +-o AppleUSBEHCI <class AppleUSBEHCI, registered, matched, active, busy 0, retain count 7>
| | | | +-o EHCI Root Hub Simulation@0,3 <class IOUSBRootHubDevice, registered, matched, active, busy 0, retain count 9>
| | +-o pci10b9,5253@0,4 <class IOCardBusDevice, registered, matched, active, busy 0, retain count 11>
| | +-o AppleFWOHCI <class AppleFWOHCI, !registered, !matched, active, busy 0, retain count 5>
| | | +-o IOFireWireController <class IOFireWireController, registered, matched, active, busy 0, retain count 10>
| | | +-o IOFireWireLocalNode <class IOFireWireLocalNode, registered, matched, active, busy 0, retain count 12>
| | | +-o IOFireWireUserClientIniter <class IOFireWireUserClientIniter, !registered, !matched, active, busy 0, retain count 4>
| | | +-o IOFireWireIP <class IOFireWireIP, !registered, !matched, active, busy 0, retain count 7>
| | | | +-o IOFWInterface <class IOFWInterface, registered, matched, active, busy 0, retain count 10>
| | | +-o AppleMLANAudioDevice <class AppleMLANAudioDevice, registered, matched, active, busy 0, retain count 5>
| | | +-o IOFireWireAVCLocalNode <class IOFireWireAVCLocalNode, registered, matched, active, busy 0, retain count 4>
+-o IOResources <class IOResources, registered, matched, active, busy 0, retain count 11>
| +-o com_apple_BootCache <class com_apple_BootCache, !registered, !matched, active, busy 0, retain count 4>
| +-o IODisplayWrangler <class IODisplayWrangler, registered, matched, active, busy 0, retain count 6>
+-o GossamerDeviceTreeUpdater <class GossamerDeviceTreeUpdater, !registered, !matched, active, busy 0, retain count 4>
____________________________________________________________________________ _________________ Wallstreet II - 320.Mo - Proc Sonnet Crescendo WS G4/500 - DD: Hitachi 40.Go+MCE Xcaret pro 20.Go - OS X Panther 10.3.9 - 2 batteries: Apple+NuPower - PCMCIA: Airport/Sonnet Aria+FW/USB - iPod mini |
Posté le: Sam 23 Avr 2005 à 14:17 Sujet du message: |
Il faut lancer le graveur avant l'ordi pour que X le prenne en compte. _________________ Ludovic
Posté le: Sam 23 Avr 2005 à 15:21 Sujet du message: |
vérifie la présence d'un bouchon SCSI sur la chaîne et un câble SCSI bien blindé (ils sont souvent plus épais que d'autres) - on dirait qu'il n'arrive pas à initialiser la chaîne. _________________ La mine d'or pour OS X - http://www.versiontracker.com/macosx/
macfun PowerBook d'Orchidée
Posté le: Sam 23 Avr 2005 à 20:56 Sujet du message: |
Apparait-il dans system Profiler ?
Fonctionnait-il avant (10.3.8 ....) ?
Apparait-il dans Toast ?
Les 2 premières remarques sont excellentes.
J'avais un Yamaha 4260 SCSI externe connecté à mon WS292 du temps de 10.0 et 10.1 : pas de prob à l'époque. _________________ * MBP 13 2.26 + écran 24" HP
Posté le: Sam 23 Avr 2005 à 21:13 Sujet du message: |
Oui, merci à vous pour les tuyaux : après ré-initialisation, je peux voir mon graveur avec Toast, bien que le port SCSI ne soit pas documenté dans Informations système ("Aucune information trouvée).  _________________ Wallstreet II - 320.Mo - Proc Sonnet Crescendo WS G4/500 - DD: Hitachi 40.Go+MCE Xcaret pro 20.Go - OS X Panther 10.3.9 - 2 batteries: Apple+NuPower - PCMCIA: Airport/Sonnet Aria+FW/USB - iPod mini |
Posté le: Sam 23 Avr 2005 à 22:32 Sujet du message: |
Initialisation de quoi ? _________________ Ludovic
Posté le: Dim 24 Avr 2005 à 12:28 Sujet du message: |
Je voulais dire : re-démarrage du PowerBook après celui du graveur Yamaha 6416. _________________ Wallstreet II - 320.Mo - Proc Sonnet Crescendo WS G4/500 - DD: Hitachi 40.Go+MCE Xcaret pro 20.Go - OS X Panther 10.3.9 - 2 batteries: Apple+NuPower - PCMCIA: Airport/Sonnet Aria+FW/USB - iPod mini |
Posté le: Dim 24 Avr 2005 à 12:32 Sujet du message: |
Le bus SCSI l'a toujours exigé :
Mise en route : d'abord les périphériques, ensuite l'ordi
Extinction : d'abord l'ordi, ensuite pes périphériques
PAS DE CONNEXION A CHAUD ! _________________ La mine d'or pour OS X - http://www.versiontracker.com/macosx/
Posté le: Dim 24 Avr 2005 à 14:10 Sujet du message: |
C'est ce que je disais plus haut  _________________ Ludovic
Posté le: Sam 30 Avr 2005 à 20:03 Sujet du message: |
Merci les amis, j'utilise mon graveur SCSI Yamaha 6416 avec Toast sans problème.
J'ai maintenant une question subsidiaire : comment puis-je graver un disque de démarrage OS 10.3 ? en utilisant XPostFacto ?
J'ai tenté de recopier l'installation du système qui figure sur le disque d'installation Mac OS X, puis de la graver, mais ce dossier système n'est pas reconnu au re-démarrage.
Une autre possibilité serait d'installer Mac OS X dans un nouveau dossier, et XPF semble nécessaire pour cela : mais comme une installation OS X existe déjà sur une autre partition, XPF ne me propose plus l'option installation.
Quelles sont vos suggestions ?  _________________ Wallstreet II - 320.Mo - Proc Sonnet Crescendo WS G4/500 - DD: Hitachi 40.Go+MCE Xcaret pro 20.Go - OS X Panther 10.3.9 - 2 batteries: Apple+NuPower - PCMCIA: Airport/Sonnet Aria+FW/USB - iPod mini |
