TNX PowerBook d'Orchidée
Posté le: Lun 31 Oct 2005 à 10:03 Sujet du message: Drivers ATI |
En allant me promener sur le site d'ATI, j'ai découvert avec étonnement que dans leur rubrique de téléchargement il y avait une rubrique avec les drivers Mac ! J'ai été effectivement très étonné car Apple met à jour les drivers graphiques avec ses mises à jour en ligne. Alors où est le truc ?
voici la description des drivers sur le site d'ATI:
Citation: |
For all ATI retail Mac graphics products, the software is made up of:
* ATI Display Drivers
* ATI Support Files (such as the ATI ROM Xtender, and ATI Displays)
The drivers from your ATI Installation CD or Retail Updates on ati.com are always Mac OS version specific, while the included support files will generally support a broad range of OS versions.
With the Mac OS X updates available from Apple's website only the core display driver is updated; all the preinstalled ATI support files (such as the ATI ROM Xtender and ATI Displays) from your installation CD or later updates from ati.com should remain intact, and continue to operate. If you are performing a Mac OS X update, you should not remove the ATI support files prior to or after updating your OS.
If you are performing a clean install of the OS, it is important to update the OS to the minimum requirements as mentioned on the retail box or the specifications page on ati.com before running your original installation CD or Retail Updates.
Similarly, if you run a clean install of an OS that is newer than what is mentioned on the retail box or product specifications page, we recommend running your original installation CD at minimum, or the latest web release of the ATI Retail Update to ensure that the required ATI support files are installed. Running without the ATI support files may cause anywhere from a loss in some features, to complete loss of acceleration and display mode options (depending on your retail hardware).
D'accord ! mais alors à quoi servent précisément ces fichiers de support ?
 _________________ TNX
Posté le: Lun 31 Oct 2005 à 13:34 Sujet du message: |
Il existe des cartes ATI qui ne sont pas installées par Apple mais vendues dans le commerce, compatibles avec les Macs - cette section sert surtout pour elles. _________________ La mine d'or pour OS X - http://www.versiontracker.com/macosx/
Posté le: Lun 31 Oct 2005 à 13:42 Sujet du message: |
On a déjà parlé de ca  _________________ Ludovic
Posté le: Mar 01 Nov 2005 à 21:46 Sujet du message: |
et c'est bien qu'on puisse aussi utiliser d'autres périphériques sur nos machines que ceux d'origine.
le passage à Intel va peut-être aussi nous faire avancer de ce côté et pousser au cul les constructeurs à développer des drivers pour notre plate-forme...  _________________ Vincent
