studio54 PowerBook Duo 270c
Posté le: Mer 18 Jan 2006 à 16:39 Sujet du message: Clavier PC et touches Apple |
Pour les switchers sur Mac mini (par exemple) avec un clavier PC.
La configuration des touches ALT et Drapeau Windows (Command ou Pomme pour mac) est différente. Un petit utilitaire a installer rendra le passage plus agréable dans le monde Fruité.
Citation: | DoubleCommand is software for Mac OS X (a kernel extension) that lets you remap keys, in other words change the way your keyboard works. Often used to make a PC keyboard more comfortable with a Mac, swapping the Alt (Option) and Windows (Command or Apple) keys, since they are in swapped positions on Mac and PC keyboards. DoubleCommand is a quick and easy way to fix this if you use a PC keyboard with your Mac. Called DoubleCommand because originally it was used to give the old PowerBooks a second Command key, where there was an enter key. |
http://doublecommand.sourceforge.net/ _________________ iPod G4 40 go, Nano rev2 8 go, Powerbook G4 15", Mac Mini 1,42 + 1go RAM, Powermac G5 2x2 2.5 Go Ram, MacPro 3 GHZ 4go ram
Posté le: Mer 18 Jan 2006 à 17:06 Sujet du message: |
Merci beaucoup pour cette info précieuse. _________________ Ludovic
