Polochon PowerBook de Saphir
Inscrit le: 20 Aoû 2005 Messages: 169 Localisation: Paris
Posté le: Mar 03 Jan 2006 à 17:51 Sujet du message: Automator et MP3 (via Doug's AppleScripts for iTunes) |
j'ai téléchargé le Doug's AppleScripts for iTunes qui mermet de re-convertir des fichiers en mp3 ou autres.
Voici le descriptif pour ceux qui ne connaissent pas:
Code: |
This collection contains seven Automator Actions for iTunes:
Get Selected Tracks or Selected Playlist
Outputs the selected tracks, or if no tracks selected, the selected playlist
Choose Encoder
Select an encoder to use on-the-fly, restoring your iTunes Preferences-set encoder with the Restore Encoder action
Restore Encoder
Restores the Preferences-set encoder stored with the Choose Encoder action
Convert Tracks
Convert library tracks or import CD tracks with option to delete the original tracks and their files
Copy Tracks to Playlist
Copy tracks from a previous action to a new or existing library playlist
Copy Tracks to iPod
Copy tracks from a previous action to a new or existing iPod playlist
Make AAC Tracks Bookmarkable
Change the file-type of AAC tracks from a previous action so that they are "bookmarkable" |
et quand j'essai d'utiliser l'action "restore encoder", j'ai ceci comme erreur:
Code: |
2005-12-31 11:27:36.880 defaults[8751]
The domain/default pair of (com.dougscripts.ChooseEncoder, defaultEncoder) does not exist (1)
2005-12-31 11:29:46.748 defaults[8759]
2005-12-31 11:30:04.619 defaults[8760]
2005-12-31 11:30:15.079 defaults[8762]
The domain/default pair of (com.dougscripts.ChooseEncoder, defaultEncoder) does not exist (1) |
e principe d'utilisation est le suivant:
- on choisit un encodeur
- on convertit les fichiers
- on remet l'encodeur d'origine
il semble qu'il n'arrive pas a remettre l'encodeur d'origine... (cf image jointe)
donc si quelqu'un a une idée pour l'erreur ou a d'autres actions ou scripts, je suis preneur!
merci _________________ Ibook 12'' - G4 1,33GHZ - 1Go RAM
MAC OS X 10.4 |
Posté le: Jeu 05 Jan 2006 à 10:22 Sujet du message: |
pas d'idées?
MAC OS X 10.4 |
Posté le: Jeu 05 Jan 2006 à 10:41 Sujet du message: |
c'est une question TRÈS précise que tu poses là... dur de te répondre  _________________ Vincent
Philpask PowerBook de Chêne
Posté le: Jeu 05 Jan 2006 à 12:20 Sujet du message: |
Surtout, quel est l'intérêt de ce script ? Itunes convertit en mp3...
Sachant que les fichiers achetés ont des drm, comment ce script outrepassent ces droits ? Peut-être ne peut-il pas réencoder à cause de cela ? _________________ No more Comic |
Posté le: Jeu 05 Jan 2006 à 14:17 Sujet du message: |
oui je sais c'est précis...
en fait, j'ai des fichiers mp3 de bonne qualité que je veux réencoder avec une qualité moindre pour envoyer à une autre personne. Et ces actions permettent justement de modifier les parametres de itunes le temps de la conversion, puis de remettre les paramètres par défaut une fois que c'est fini. Combiné avec d'autres actions automator, ça peut être super puissant comme outil...
Et je n'ai rien trouvé d'autre sur internet pour faire ça...
Si personne ne sait tant pis mais si quelqu'un a déjà essayé ça pourrait m'aider!
voilà... _________________ Ibook 12'' - G4 1,33GHZ - 1Go RAM
MAC OS X 10.4 |
Posté le: Jeu 05 Jan 2006 à 18:01 Sujet du message: |
il y a beaucoup de choses, mais peut etre ma reponse...
merci pour le lien! _________________ Ibook 12'' - G4 1,33GHZ - 1Go RAM
MAC OS X 10.4 |
